Airfix 1/76 Sherman Crab
Posted by huib on 15 Aug 2019, 14:50
Weathering (2)
Weathering is finished applying a drybrush of light grey-green (Revell 43), mud in three shades of brown, a bit of additional chipping using a graphite pencil (creating a nice soft metal shine) and two layers of matt varnish.
The flail, here with a bit of rust and sand.
And here with its full share of mud. The balls on the chain's end were drybrushed with steel colour, as in reality they show bare metal here.
The hull side, with some mudd around the wheels and tracks.
Mud from the flail on the differential cover.
And mud on the flail arms.
Some extra chipping on the turret.
And a dryfit.
Almost ready now, only a few details left.
Posted by Peter on 15 Aug 2019, 17:23
Wonderfull! :thumbup:
And as this one is almost finished, I'm allready looking forward to your next project! ;-) :thumbup:
Posted by MABO on 17 Aug 2019, 11:05
Peter wrote:Wonderfull! :thumbup:
That is exactly what I do! Another breathtaking project. Really cool to see the result.
Posted by huib on 18 Aug 2019, 13:09
Thank you guys!
My next project will be an aircraft, and I never post these on Benno's, as there are no figures involved. :(
Posted by huib on 18 Aug 2019, 13:31
The last details
Some small last parts to finalise the Sherman Crab:
Two axles, two pistons and a drive shaft to connect the flail to the tank.
The connection is definitely made now. The driveshaft, in white, will be painted. The piston in metal, will remain metal. To get a nice straight line I had to change the angle of both the cilinder and the receiving end on the flail side.
The Sherman Crab was equipped with a visual system to cooperate in echelon with other crabs to clear a minefield without forgetting strips of land. (Very wise idea). Here you see this installation on the back of a Sherman Crab.
The basic material is 0,7mm household iron wire.
A full parts layout. (So called exploded view)
All parts glued together using CA glue.
After painting and weathering.
The white "mirrors" to guide the following tank.
The system glued to the back of the hull.
Shermans had a towing cable as standard equipment. I like to make these myself from copper wire salvaged from a household electricity cable. Four wires will do for a 1/76 heavy duty towing cable.
The copper wires twisted into a cable and eyelets added.
The eyelets are made from thin iron wire (0,5mm), a piece of modelling tape and a drop of CA glue.
Towing cable painted, weathered and pre-bent.
Cable glued to the hull.
A British WW2 tank commander from Hät. This figure has a very strange pose which I don't like, so I changed the position of his head and right arm.
The commander after cosmetic surgery in dark grey primer.
Painted and weathered.
And, because of theior vulnerability always the last parts to add, two radio antenna's and an antennna base from copper wire.
Finished!!
Final pictures soon.
Posted by Wiking on 18 Aug 2019, 15:12
Hmmm ...
Now your olive green vehicle look like a harvester with a parking assist system.
And the lunch is fixed at the back.
:oops:
Posted by Bluefalchion on 18 Aug 2019, 15:14
huib wrote:Thank you guys!
Well then have a ground crew working on an open engine compartment on your model plane.
Problem solved.
Posted by Dad's Army on 18 Aug 2019, 17:56
Problem solved.
or ad a pilot :mrgreen:
great job again Huib, love your conversions of these models!
Posted by huib on 19 Aug 2019, 11:38
Thank you very much guys!
Final pictures are ready!
For all pictures, please have a look in the Gallery
