Drills?
Posted by Traveller1865 on 18 Apr 2018, 15:26
What drills do you use for 1/72? Especially for drilling hands?
Traveller1865  Sweden
In memoriam
07 Feb 2017, 19:51
Posted by FredG on 18 Apr 2018, 15:52
Posted by Paul on 18 Apr 2018, 16:07
Hand drill with drill bits ranging from Ø 0,3 - 1,2 mm
Posted by Graeme on 19 Apr 2018, 03:01
My pin vice drill looks like this:
And my set of mini drills looks like this:
And I wouldn't be without them. This kind of stuff should be available at your local hobby store, or plenty online.
Posted by FredG on 19 Apr 2018, 07:55
Hand drill?
With my propensity for impaling I use a power screwdriver :-D :beer:
Posted by Peter on 19 Apr 2018, 11:15
I use a Dremel for metal figures and a hot needle for plastic figures! ;-)
Posted by Beano Boy on 19 Apr 2018, 13:20
I have metal figures coming,well some arrived today.
I have a dremel Mrs B, bought for me yonk`s ago.
She will be pleased as punch to see it in hum drum practice.
So I need some drills now.
:mrgreen: " You could do cheap tooth fillings on the side BB."___ :shock: " EKK!" __ :sst: "o`, no."
:coffee: No, I`d sooner write about it
because then the screams of share horror
would be quite silent indeed.
Thank you guys for such a combined thought provoking topic. BB
Posted by Traveller1865 on 19 Apr 2018, 15:32
Peter wrote:I use a Dremel for metal figures and a hot needle for plastic figures! ;-)
Cheap and clever!
In memoriam
07 Feb 2017, 19:51
Posted by Paul on 19 Apr 2018, 16:16
FredG wrote:Image
other makes of power drill are available :mrgreen:
Posted by FredG on 19 Apr 2018, 16:20
Paul wrote:other makes of power drill are available :mrgreen:
But I don't use them :beer:
Posted by Wiking on 22 Apr 2018, 09:49
I use both.
Electric power by my old Proxxon. A survivor of my radio controlled car time.
As an hand drill.
Both is each for his duty very usefull.
The Proxxon for connecting (resin, plaster, plastic, wood) houses , walls, streets, the base plate by drilling a hole for a connecting pin.
If you have to drill in thin material additional with an angle like connecting a hand to a soft or hardplastic figure the hand drill is a great tool. Also for drilling the hole to fit the figure wtih pin into the Dio.
The back side of the drillbox is used to mix color. :oops:
Posted by FredG on 10 May 2018, 19:04
These turned up in the mail today.
0.3 - 1.2mm
Posted by Wiking on 10 May 2018, 20:43
The Impaler get new tools!
To break new ground?
:mrgreen:
I wish you all the very best a steady hand for the 0.3 , 0.4mm drills.
Posted by stenfalk on 11 May 2018, 21:09
FredG wrote:These turned up in the mail today.
0.3 - 1.2mm
I also use these packs, I always buy at least three at a time. Especially the very thin drills break off easily. But this is not a quality deficiency, but simply the nature of the thing.
stenfalk  Germany
28 Apr 2016, 15:08
Posted by Beano Boy on 11 May 2018, 21:46
Call me silly but to avoid buying drill bits that break easily I used to use pins with the heads removed.BB
Posted by stenfalk on 13 May 2018, 21:17
Beano Boy wrote:Call me silly but to avoid buying drill bits that break easily I used to use pins with the heads removed.BB
But that works only in soft material, right? I'm afraid there is no real alternative to drilling for my requirements; the drills break only if i'm not careful and deviate the drill from the "entry angle" while drilling. Unfortunately, it happens to me more often than i wish ... Fortunately, the drills are quite cheap, if they come from China! :oops:
stenfalk  Germany
28 Apr 2016, 15:08
Posted by Beano Boy on 13 May 2018, 23:11
Mrs B,kindly bought me a Dremel power tool years ago. I only used it a few times before it went missing. However I`ll try anything once.....
...... so I used a small masonry pin in it which had been taken from a coaxial cable clip with its tail cut off to drill soft metal out ,plastic and even pilot holes in wood. :mrgreen: ` Is this a wind up?'
Well it certainly went around and around while pushing it in. :-D BB
