Ardennes Diorama
Posted by Quepwik on 20 Feb 2018, 14:22
Here is my new project that I present to you, a diorama in the Ardennes.
It depicts a movement of troops and vehicles just before the famous report of road crossing at Kaiserbaracke (where we see the famous schwimmwagen in front of the panel Malmedy / St Vith and the passenger has long taken a long time wrong for Peiper) .
At this cross of Kaiserbaracke the Hansen Group separates from the Knittel Group.
I will locate my diorama near the village of Born, a few kilometers before Kaiserbaracke, early in the morning of December 18, 1944.
A Sdkfz 250 Neu, member of the Knittel group, has joined one of Hansen's group Jagdpanzer IV and has to exchange on the guidelines to follow.
The two columns will probably mix from here to separate a few kilometers further to the crossroads of Kaiserbaracke, what we see in the video mentioned above.
The ingredients of the project will be:
- A Sdkfz 250 Neu [MK72]
- A Jagdpanzer IV [Dragon / Hasegawa]
- Ardennes House [DioDump]
- Probably a bike [Preiser] or a Kubelwagen [?] If the place allows it.
- Then, various figurines of tankers and panzergrenadiers.
The editing of the Jagdpanzer IV is already well advanced despite some failures.
At 1/72, the catch is that none of the main available references (Dragon, Hasegawa and Trumpeter) are correct.
We will say that the least worse is that of Hasegawa but we must keep the idea to change the running gear, coming from a Panzer IV Revell for example
Unfortunately, the installation of the fenders in photoetched on the model went wrong. I do not really understand where the problem came from, but they were wider than necessary and were a good millimeter above the casemate. A gagging attempt to make up for it went wrong.
So I opted for the "B" plan, the pose of the Hasegawa's casemate on the model Dragon.
The transplant took well, there was no rejection!
The casemate fits very well to the Dragon sill even if it is a little bit too wide. After small blow grinding / sanding, we now see only fire.
Other ingredients have gone into the dance: Photodécoupe Part, RB Model cannon, some Revell pieces and 2-3 home crafts, which give this. And finally a painting challenge to raise for camouflage in "camo discs", at 1/72!
Less talk, now photos :
More photos in my blog : http://scale72world.blogspot.fr/search/label/Ardennes%20Diorama
Quepwik  France
20 May 2015, 16:38
Posted by Bill Slavin on 20 Feb 2018, 16:24
Nice work! I look forward to seeing things progress.
Posted by stenfalk on 20 Feb 2018, 16:55
This reminds me of earlier times, when I was still building vehicles. It was always fun...
But watching your modeling activity is also fun. Very nice work so far, hopefully new photos will follow soon. :yeah:
stenfalk  Germany
28 Apr 2016, 15:08
Posted by Wiking on 20 Feb 2018, 18:26
A lot of details for the Jagdpanzer as the interior for the nice done Sd kfz 250 of MK.
I like the way of building the hard plastic track in one section very much.
And I am a bit surprised that beside ACE it is the only available plastic kit.
Non of the big manufactures do a Sd kfz 250.
Maybe you know it already.
If you get the option to get an Kübelwagen from S-Models , use it.
It is by distance the best detailed kit, if available.
Hope to see soon some progress.
:yeah:
Posted by Quepwik on 21 Feb 2018, 09:17
Many thanks !
So, I will try S-Model Kubelwagen.
The MK72 models are really beautiful.
Quepwik  France
20 May 2015, 16:38
Posted by Quepwik on 26 Feb 2018, 21:11
Here we go for painting:
First the primer, Mr Surfacer 1200.
Then the 2 brown and green colors of the German camo (and the macro photo makes me say that it will be time to invest in a real good airbrush!) :
Then the tedious job with simple cookie cutters.
Masking tape on a small piece of wood, neither too hard nor too soft.
I used the diameters 1 - 1.5 and 2mm
And that gives this:
Next step, the yellow-sand.
Hoping that it produces the right result
Quepwik  France
20 May 2015, 16:38
Posted by stenfalk on 26 Feb 2018, 22:01
You're a little bit crazy - in a very positive and engaging way... 8)
stenfalk  Germany
28 Apr 2016, 15:08
Posted by Quepwik on 28 Feb 2018, 10:12
And gentlemen, I present you a good model for the trash!
The worst happened. The mask created an extra thickness and the paint drooled.
We call it a disaster and money fucked up!
I will try to fix that, I do not know how.
But I'll have to go to "Plan B" if I want my diorama to be finished for Saumur Modelshow Contest.
I will look for another vehicle to replace it. The Kampfgruppe Knittel also had Schwimmwagen, Sdkfz 222 and Puma of different types. The Hansen group also had Grids. Or else, I go on a Tiger II Peiper Group, which I have in stock.
For the "repair" I have to find the right product stripping and I would then try a more classic painting broadband. finish the lozenges at the moment. Fortunately, I can save the rocker that was not glued. So I must strip "that" the top. I'm already going to soak in water and overdose powdered laundry to see.
Beyond painting and masking, anyway, I am absolutely not satisfied with the look and the shapes between the circles. It's not at all what I wanted to happen. The spaces were too big.
It's been a long time such a mess had not happened to me! It must be said that I cumulated the risks with this method of painting with caches and the test of a new painting of the AK Interactive range.
Double test, double unprocessed.
I leave this step in hibernation in a distant cave!
Quepwik  France
20 May 2015, 16:38
Posted by Kekso on 28 Feb 2018, 10:39
I'm sorry that you have problems but I hope you'll finish it in time.
I would like to hear more about those "cookie cutters". Are they self made or can be bought online?
Posted by Dukebormi on 28 Feb 2018, 10:54
Hi Quepwik
your mistake was
You have set your airbrush too high
lower and distance at least 30-40cm
is better :yeah:
have similar Problems :eh:
Greeting
Dukebormi  Germany
02 Oct 2009, 08:10
Posted by Wiking on 28 Feb 2018, 12:35
Shit happen.
I saw your idea and thought , simply great!
But your result is not what I have expected.
Head up Quepwik!
Schwimwagen: Academy
Sdkfz 222: ICM (with etched parts)
Puma: Hasegawa
You are a great modeller. You will find a good sulution. I am me sure about that.
Posted by Bramble15 on 28 Feb 2018, 16:28
Before you trash it and start over possibly try a very light grit wet sand. First clear coat (gloss) the entire vehicle. Then with either light or medium grit sandpaper wet sand the entire area.
I used to get that end result quite a bit when building NASCAR models that had multiple color paint schemes.
18 Aug 2010, 22:25
Posted by Quepwik on 28 Feb 2018, 19:52
Thanks for your advice.
I wil try something
Quepwik  France
20 May 2015, 16:38
Posted by Quepwik on 02 Mar 2018, 11:32
The Glanzer method seems to work perfectly.
My tank is now completely pickled.
All is not lost. I refinish the stripping to make it almost new!
Thank you all for your advice
Quepwik  France
20 May 2015, 16:38
Posted by Beano Boy on 02 Mar 2018, 13:01
Very glad you sorted it. BB
Posted by sansovino on 02 Mar 2018, 19:38
It´s a pity that it didn´t work. I hope you can save and rework still your tank...
I like people who dare anything new although they risk to fail....
sansovino  Germany
27 Mar 2014, 21:42
Posted by Quepwik on 05 Mar 2018, 08:39
It is I who made a mistake in the dilution of paint, the method works.
Look at the beautiful work of Mark Kleinfelter:
http://www.network54.com/Forum/47210/message/1519862495/A+suggestion
Quepwik  France
20 May 2015, 16:38
Posted by MABO on 06 Mar 2018, 21:21
Ok, thanks for sharing!
Posted by Quepwik on 07 Mar 2018, 15:10
The Glanzer did the trick!
Some loose pieces (including the front mudguard lost right) and putty for the raw rendering of the mask to be redone but the main is saved.
However, some pieces have become brittle, such as the schurzen supports.
I did not take the risk of inferring soft caterpillars. So I soaked and rubbed several times the front and back of the underside.
As a reminder, BEFORE FIRST PAINTING:
AFTER GLANZER STRIPPING:
In case, I still went to B plan in duplicate with a Puma (Hasegawa) of Kampfgruppe Knittel. I know they exist but unfortunately, not much info on it. In all, the Kampfgruppe, reconnaissance unit I remind you, had to have 16 Sdkfz 234 of any type (1, 2 and 3). Some are also survivors of the Battle of Normandy and other brand new perceived just before this offensive.
More photos here : http://scale72world.blogspot.fr/2018/03 ... art06.html
Quepwik  France
20 May 2015, 16:38
Posted by Carlos on 09 Mar 2018, 13:14
The disc camouflage scheme has driven more than one crazy including me, I've tried several tenicas, including screens like you, but it did not work out either.
Finally what I do is take a color fiber marker, cut the tip, wet it in the paint and make the disc marks with that.
It requires some practice, and there is no perfet result, but it is the best I could find.
Carlos  Argentina
19 Sep 2016, 14:41
