Good afternoon all
Hope this finds you well.
I am changing the name of this thread because, as you can see the scenery is coming to an end, and I am moving on with adding some figures.
So, this week I started on finishing the last of the big Middle Earth pieces - which paradoxically was actually the first of the big ME pieces.
That was the middle of April and it was really a test piece to see what I could do with polystyrene sheets.
Turns out that, apparently, you can do quite a lot with them.
To bring this completion, first off I mounted the building on a polyeurothane board, and added grass mat.
Once that was glued down I added some beach sand, over tacky glue to 'blur the edges' of the building and where the joints of the grass mat were. Once that had set, I sprayed it with the matt medium mix (50/50 matt medium and water + a couple of drops of washing up liquid), to stabilise it, then I added some grit over more tacky glue (and another spray of matt medium) followed by some old grapevines for old tree trunks.
This wall will be largely covered by rubberised horsehair and clump foliage.
I suppose that once the blue styrodur blocks were painted I could really leave it like that, couldn't I?
No.
Of course i can't.
Time for some greenery and lots of it.
Et Voila!And I think that will do.
I could have done more with it, some of the rubberised horsehair inside the ruin, but I also want to be able to place up to twelve 20mm round bses in that space, so I probably will not.
The only thing left scenery-wise is the mound on which the Seat of Seeing will stant, but I will keep that for next week.
I know Sean Bean said that I'd brought a cave troll but he was lying. These two Troills are from Alliance's 72030 War Trolls. Set1, I've had them years and it feels like now is a good time to get them done.
Went through my usual processes - based them on 40mm wooden disc bases, put mod podge and tile grout mix on the bases. A white undercoat, followed by Vallejo Dark Skin tone, Washed the figures with my dirty wash mix, then dry brushed them up with Dark Skin tone first, then the same with white mixed. The scaley flesh was done Vallejo Air Black mixed with the Dark Skin tone to get a dark grey, dirty washed and then dry brushed with a light tone of the Black/Dark Skin mix.
The thin Air Black was painted over the armour sections as a base, then various mixes of Vallejo steel and black and assorted washes were used, to get armour that looked like it has been badly abused.
I think I will go back and add some more detailed black wshes, around certain areas to bring up the details, but overall, I think they will do nicely.
I will leave the bases until I know what I am doing with the rest of the army.
Thank you for looking in, stay safe all. Pickers.
(22894)
