Ochoin wrote:Steve, a percentage of mine are textured: just not as good as yours.
At one stage I used GW's "cracking paint" : very expensive for a so-so effect.
Tell me more about this super-glue-&-baking-soda.
Never tried the cracking paints, I may have to have a go.
Super glue/baking powder is very simple. I saw it mentioned on a youtube video and gave it a go for myself.
If I am basing figures I normally glue the figures to the base using a 'clear' glue like Bostick or similar. Once that has set - take a cheap superglue - preferably a fairly runny one with a nozzle for better control - the ten packs you get for a quid in Poundland and places like that are good.
Working in a well-ventilated area (sorry but the fumes can be something else) apply the glue to the base. I usually slop it on, covering the edge of the pill base, to cover that joint, and fill in any blank areas. Obviously take every care to not get any superglue on the figure.
Then I take a tray of baking powder and dip the figure base into the powder and shake the excess off.
The glue/powder mix hardens virtually instantly! You can paint it seconds later. It's as hard as nails, stuck like stuff on a blanket, and it has a really good scale texture. It's finer than the finest sand, so in 1/72nd scale it looks spot on.
This first picture shows how it smooths out the edge of the base and how good the texture looks.
The same technique is used when doing movement trays, however avoid getting any glue/powder mix into the slots (the Warbase one are pretty snug to begin with). There is nothing to stop you building the layers up with more superglue and then more powder. Take care not to touch the nozzle of the glue to any powder on the base as it will react and solidify in the nozzle.
When you are ready to paint the bases, first give them a good brushing with a fairly stiff old paintbrush to get any remaining powder off the bases and the figures/models. Once I've done the basic colour on the base, I dry-brush it a couple of times to get a depth of colour, and then tufts and flock are applied over that. These figures had scenic bases so you can see how the glue/powder blends them in quite nicely.
In this picture you can see that I used some smears of
Miliput on the movement tray, which the got the glue/powder treatment, along with little bits of twig, to add a wasteland feel to the bases.
I added a skull to Danthe's base and then textured it in, to look like it had been there a long time.
Another thing you can do with the glue/powder mix is to use it to texture polystyrene. Put super glue on the surface - cover it completely, sprinkle on the powder and wallop! you have quite an effective rock texture. It is exothermic, so it does give off a fair bit of heat while it is setting, but not enough to melt the styrene.
These are broken bits of masonry wielded by Amon Bob the Pyramid Builder, which he then throws at the enemy.
Hope this is useful.
