islands
Posted by Ochoin on 28 Sep 2017, 16:54
I thought I needed islands, to put in the Nile for my Mahdist War games.
Made from MD foam, these are the first two:
Posted by Graeme on 28 Sep 2017, 17:34
The cliffs look good. Tricky submerged reefs though.
Posted by Beano Boy on 28 Sep 2017, 20:08
Good idea. BB
Posted by Mr. Andrea on 29 Sep 2017, 09:57
I planned to do the same; only I need hills for my war games. I've been told the foam it's pretty sticky and may create huge mess if not used in proper environment. I guess you haven't done it on the kitchen counter (at my place, that would be sort of sadism). Have you used rubber gloves? On what surface have you sprayed the foam? Thanks
Mr. Andrea  Europe
18 Mar 2015, 12:43
Posted by Ochoin on 29 Sep 2017, 11:05
Mr. Andrea wrote:I planned to do the same; only I need hills for my war games. I've been told the foam it's pretty sticky and may create huge mess if not used in proper environment. I guess you haven't done it on the kitchen counter (at my place, that would be sort of sadism). Have you used rubber gloves? On what surface have you sprayed the foam? Thanks
No, it's not sticky at all and easy to work with .
Medium density board is designed to be carved. It's not the white polystyrene stuff .
There are shavings (of course) and dust (wear a mask when sanding) so *not* in the kitchen. I have a shed to work in.
Posted by Mr. Andrea on 29 Sep 2017, 12:18
Thanks, Donald. Now I got it. My mistake: I thought of the expanding foam.
Mr. Andrea  Europe
18 Mar 2015, 12:43
Posted by FredG on 29 Sep 2017, 15:32
Ummmm, that looks familiar.
:-D
