Posted by Zed1 on 29 Jan 2012, 19:48
Well - if you're about to make photos of the city, you most probably want to visit Montmartre hill and the cathedral Sacre Coeur anyhow. At least, I would do so because the view over the city, especially on a sunny day, is marvellous.
I would recommend to go there the other way round and step up the hill from the backside. Drive with the Metro to Lamarck/Caulaincourt, follow the Rue Caulaincourt a bit eastward, then go right following the Rue Lamarck in eastern direction. Gives you some impression how the backyard of Paris looks. After a few hundred meters, go right into the Rue du Mont Cenis and at the next crossroads leftward. Between the houses, there are stairways going upwards. Take one of them - a hundred steps upward, that make a good photo as well as they lead you into the backyards of the cathedral hill. A place, where you will find small, old houses that make a strange contrast to the rest of the city. Small gardens will guide your way up to the cathedral and it's interesting construction.
