1/35 Dragon "Falshirmjaeger Tank Hunters"
Posted by gerry7944 on 19 Feb 2017, 16:15
This is a small vignette using Dragon figures depicting the desperate days in the bocage as the German troops try to defend against the allies after D Day.
I have used Vallejo model paints on the figures and the base is an old picture frame.
Cheers
Gerry
gerry7944  United Kingdom
07 Oct 2016, 04:49
Posted by Bluefalchion on 19 Feb 2017, 17:32
Great job. Love the details on the straps, packs, buckles, belts etc. I also dig the camo patterns, and you do a great job with the scenery and faces.
Posted by C M Dodson on 19 Feb 2017, 19:25
Hi Gerry, fantastic as usual and certainly setting the bar.
If I may respectfully suggest that the arm joins would benefit from a little light filling?
I personally like to use natural materials for scenery. I am not sure how Guagemaster products would look in 1/35 but it certainly works in 20 mm.
Best wishes, as always.
Posted by gerry7944 on 20 Feb 2017, 20:39
Bluefalchion wrote:Great job. Love the details on the straps, packs, buckles, belts etc. I also dig the camo patterns, and you do a great job with the scenery and faces.
Bluefalchion
Thanks for that.
Much appreciated.
Cheers
Gerry
07 Oct 2016, 04:49
Posted by gerry7944 on 20 Feb 2017, 20:43
C M Dodson wrote:Hi Gerry, fantastic as usual and certainly setting the bar.
Thanks for that.
Much appreciated.
This was one of my first dios after getting back into the hobby.
I was a bit lazy then and did not fill or sand joints which I should have done.
I too will use natural products but sometimes the problem is getting them into scale which I find a bit easier using synthetic products.
Cheers
Gerry
07 Oct 2016, 04:49
Posted by Hellboy on 23 Feb 2017, 11:49
Hi Gerry, a great work from you - as always !!!! :yeah: The diorama radiates a real tension! Incredible!!!!
What fascinates me is the many pieces of equipment of the soldiers. Soooooo..... many details. :shock: What a pleasure to look at !!! :-D
Hellboy  Germany
10 Feb 2016, 19:34
Posted by gerry7944 on 24 Feb 2017, 12:39
Hellboy wrote:Hi Gerry, a great work from you - as always !!!! :yeah: The diorama radiates a real tension! Incredible!!!!
Hellboy
Thanks for that.
Your comments are very much appreciated.
Cheers
Gerry
07 Oct 2016, 04:49
