The separate weapons make this set quite hard work, which can spoil some otherwise great figures. Mounting the horses on the bases also adds to the amount of work that most will be faced with to make use of this set, which will limit its appeal, but if you are prepared to invest the time and patience then you will have some really nice and exotic models on your hands.
je_touche wrote:I suggest not to read PSR as the gospel. His (!, this is one single man actually, forgot the name) reviews are more often than not rather erratic, to say the least.
I agree as to pose numbers. This should be a clear 10. Re sculpting, every single sculpt of Alex's would deserve a ten as compared to the produce of most manufacturers. But the amount of detail is not the only criterion for sculpting. What lets this set a bit down in my opinion are the horse sculptures and poses. But that's me, and I won't enter into a discussion about horse anatomy again, I did it when Alex first posted his masters.
Re the necessity to fix and glue seperate parts, that is completely hilarious. In order to achieve natural poses you very often have to have seperate parts, that should present no problem at all and should not be a reason for giving a lower rating.
Susofrick wrote:He (Dave something I think) makes a tremendous job only buy showing all those sets.
Valdemar wrote:
In mind mind no match to what Alex and I do...
Best regards
Valdemar
