Looking to see if there’s a set out there that contains figures that could be used as Cretan mercenary archers for the post Marian Reform Roman Empire. Started searching but most mercenaries I’ve found are of the Eastern variety with conical helmets. Any help would be appreciated.
Hace a look at zvezda/italeri Green hoplites I Believe, there are two useful poses for you.. Other option is Hat Alexander light infantry..these set is very genéric in plain túnics
I second Carlosfaro, I used the archers from Hät set 8044 Alexander Light Infantry, and I gave them little shields from the same set. I also used the archers from Zvezda set #8005 Greek Infantry.
