General Wargaming
Basing sizes for 1/72 DBA armies
Posted by chen on 14 May 2010, 13:31
Hi mates,
I'm thinking of building an ancient period army for wargaming use under the DBA rules in the future. Figs used will be 1/72s of course. It seems to me that all DBA armies' basing sizes are "modulized" and say, the base for 4 blade men is 40mm x 15mm, and 40mm x 30mm for a 3-knights base, in 15mm scale. However, I've no idea what the standard sizes (if there is any) should be for gaming in 1/72. After having a look into the rules I got the impression that the width of bases counts in the game. So I think I'd better make this point clear before getting into the work.
PS: since I'm totally new to wargaming, it'd be of great help if someone could put up their finished DBA armies here. This will surely provide me with lots of inspirations.
Thanks a lot in advance for your help! ;-)
cheers, chen
chen  China
26 Nov 2007, 22:50
Posted by Wheeling Turn on 14 May 2010, 13:57
Take the sizes for 25mm figures, they work really well.
:thumbup:
Wheeling Turn  Germany
14 Dec 2008, 14:05
Posted by luchs on 14 May 2010, 18:43
yes use the rules for 25mm..
the old british 25 mm is about the size of modern plastic 1/72..
i made a dba celtic army with plastic figs and based them for 25mm rules..
DBA celtic light cavallery..
warband
the complete army..
luchs
29 Mar 2009, 10:22
Posted by chen on 14 May 2010, 19:45
Thanks mates. I too think the sizes for 15mm might fit the 25mm figs. But units like camel riders (3 camels on a 40mm x 30mm base), or 40mm x 30mm bases for 7-8 hordes in 25mm seem a bit too crowded, no?
chen  China
26 Nov 2007, 22:50
Posted by luchs on 14 May 2010, 19:56
chen wrote:Thanks mates. I too think the sizes for 15mm might fit the 25mm figs. But units like camel riders (3 camels on a 40mm x 30mm base), or 40mm x 30mm bases for 7-8 hordes in 25mm seem a bit too crowded, no?
the purpose of basing in the dba rules is give a visual image of the density of the formation on the battlefield..
so more crowed are the figs more dense and disorderly is the fomation..
luchs
29 Mar 2009, 10:22
Posted by chen on 14 May 2010, 22:48
Thank you Luchs. Your Gaul army looks great. I like very much the dead Roman soldier on one of these bases.
chen  China
26 Nov 2007, 22:50
Posted by despertaferro on 15 May 2010, 01:05
Hi Chen, all my ancient armies are based for DBA rules, so if you look at my posts (subjects until XVth C.) all of them are based following DBA base sizes for 25 mm.
Here you have an example of Horde, 7 figures in a 40 x 30 mm base.
http://www.bennosfigures.com/forum/view ... 1&start=15
My only complaint would be that 40 x 20 mm base is too narrow for a 4 blades or 4 spears
http://www.bennosfigures.com/forum/viewtopic.php?t=2117
If you need a picture of some specific arrangement, just ask. I have not camels though...
despertaferro
25 Apr 2009, 18:18
Posted by bilsonius on 15 May 2010, 02:12
The 60mm wide bases for '25mm' figs are ideal for 1/72, though even then the 40mm depth for Cav can be a bit tight if hooves and manes are flying.
The different numbers of figs for Warband, Aux and Horde are in connection with the gradings for DBM, and don't apply in DBA - just use what looks good (I've been toying with the idea of a couple of bases of 5 or 6 pezhetairoi for the 'synaspismos' effect...)
bilsonius  United Kingdom
08 Feb 2009, 02:31
Posted by Cameronian on 15 May 2010, 10:31
I always use the 60mm width. Try putting 4 Zvezda spearmen or 3 Cv or 4Kn on a 40-wide!
Cameronian  Scotland
20 Apr 2010, 21:21
Posted by despertaferro on 15 May 2010, 13:42
You are right, I made I mistake.
All my bases are 60mm wide, not 40.
Sorry
despertaferro
25 Apr 2009, 18:18
Posted by Maurice on 15 May 2010, 14:02
I also use the 25mm rules for DBA bases, here's my DBA 1.1 30B Oscan army (HaT and Odemars) in progress, all on 60mm wide bases. In this case all are 60x30mm except for the 2x3Cv which is 60x40mm. Works perfectly (only 5 bases so far and still very much a WIP):
Maurice
04 Jan 2009, 15:59
Posted by chen on 15 May 2010, 14:17
Thank you gents! I'll go for the 60mm-wide bases, the armies shown in all of your pictures have just perfect feeling of formations. :thumbup:
cheers
chen
chen  China
26 Nov 2007, 22:50
Posted by bilsonius on 15 May 2010, 17:39
For more inspiration, have a look at some of these, if you haven't seen them already. See especially Reinhard Sabel's work, for 1/72 plastics, including two great BBDBA armies:
http://www.fanaticus.org/DBA/armiesofth ... index.html
08 Feb 2009, 02:31
Posted by PitYak Studios on 17 May 2010, 22:01
and don't forget to check out this awesome BUA
http://fanaticus.org/DBA/eyecandy/bua/bua49.html
PitYak Studios  New Zealand
20 Apr 2009, 00:13
Posted by chen on 17 May 2010, 22:35
Indeed ... :love:
I've just definitely and irreversibly fallen into the blackhole of the ancient periods. :drool:
chen  China
26 Nov 2007, 22:50
Posted by Cameronian on 02 Jul 2010, 13:00
Some of the figure numbers in DBA are given to suit players of DBM (DBA's bigger and older brother), so that they could use already held elements. All the double-based 8 figure elements are from DBM, DBA itself doesn't use double-basing. From what I can gather the 3/4 figure elements was to do with regular and irregular troops in DBM; something which doesn't come into it in DBA. The current DBA rules version is 2.2 and has ex DBM info in it. Apparently there is a V 3.0 on it's way which gets rid of the anomalous elements, e.g 4Kn.
I use the 60mm frontage for my 1/72 armies but a dry run for fit is advisable if using Zvezda, 4Sp can be a tight squeeze.
Zvezda persians.
Zvezda Carthaginians plus one HaT on extreme right (Zvezda only give 3 of that pose :angry1: )
Cameronian  Scotland
20 Apr 2010, 21:21
Posted by chen on 02 Jul 2010, 19:50
Thank you SV52, I've started basing my imperial Romans with 60mm frontage and I'm mostly following the advices in the official DBA rules as for the figure numbers (I don't know what version the one I have is). Your armies give me a perfect vision of what is to be expected. They look fantastic, and so are those in your blog! :thumbup:
With the frontage problem set down, I'm now concerned with other questions. I can't see why the rule suggests that only 3 auxiliary infantries be mounted on one base, since they were in fact real normal infantries only with a non-Roman civil status. I'm also getting out of the rules a bit when deciding the base depths. I'm using 60mmX20mm bases for swordmen and 60mmX30mm bases for spearmen only for security consideration.
I also got myself a StreletR set of auxiliaries in 2-rank formation poses. I find this formation shown on the box art really tempting and can't help thinking of making 7-figure bases (4 in the front and 3 in the back) to depict this ... Would all these cause problems in games?? :oops: :oops:
chen  China
26 Nov 2007, 22:50
Posted by Cameronian on 03 Jul 2010, 09:05
First of all thanks for the compliment :oops:
3 or 4 on a base is a DBM hangover, 3 figures represent 'irregular' troops and 4 figures represents 'regular' troops. In the case of Roman auxilia, I would say they were Regular as they were professional soldiers rather than warriors like say the Celts. Only my opinion of course. Yup depths do become a problem, figures holding spears vertically make life easier. The rules say that depth is less important than frontage, however if you use a non-standard depth, say 4Sp on 30mm, then you may need to identify the element as 4Sp to an opponent.
If you don't intend to play in competitions or club games it doesn't matter, you suit yourself. If you used a 7 figure element, it only counts as 4Sp on a deeper base (no double-based elements in DBA despite listing them in the rules). Alternatively, you could identify it as 2x4Sp (two elements one behind the other giving rear support) this fits nicely on a 40mm deep base. In this case rather than one element it is a group for movement purposes, the disadvantage is that if the front element is destroyed so by necessity is the rear one - half way to a lost game. There's a short discussion on this very thing with Pk on Fanaticus forum at the moment.
It's all great fun, after all that's why we do it. :mrgreen:
Cameronian  Scotland
20 Apr 2010, 21:21
Posted by chen on 03 Jul 2010, 13:08
Thanks a lot, SV52! It's much clearer to me now. I've decided to give a go for the 7 fig base and I won't mind to consider it as 4sp. Because what we do so much here is to make the army and the battle look nicer, isn't it? ;-)
BTW, I've also found the number problem for each pose in Zvezda's sets. In the auxiliary inf set, there are only 3 slingers, really an embarrassing situation. :angry1:
chen  China
26 Nov 2007, 22:50
Posted by Cameronian on 03 Jul 2010, 20:26
You might find this interesting over on TMP:
http://theminiaturespage.com/boards/msg.mv?id=201626
The point about using the DBM army lists is a valid one (I use them myself). What DBA doesn't tell you in its army lists is what troops are represented. The armies I'm working on at the moment are DBA II/19a)b)c)d) for the Seleucid empire, the list covers 320BC to 83BC. Over this period of time the troops changed quit a bit, the details of which do not appear on the DBA list but do appear on the DBM lists. For example army d) has a 4Bd element, only by referring to the DBM list do you find out that they were 'fake Roman legionaries'.
There are four DBM books of army lists, one for each of the same periods as the DBA sections. They can be quite expensive with the added complication that a new version called DBMM was released last year with updated army lists, mine are second edition DBM from 1998. If you aren't worried about having the latest and greatest and I think the differences are minimal anyway, then you should be able to get old versions at a reasonable cost on e-bay or generally on the 'net.
Cameronian  Scotland
20 Apr 2010, 21:21
Return to General Wargaming
