Paul wrote:"Bugger it" I thought, as I looked at the horse through my lens, "It´ll have to do":(
Just a mo!!!!!. My lens!!!!! the sun is shining and sun + a lens........
Dug out my sunglasses went out side and lo and behold, the usual trick of concentrating the suns rays to create a fire worked absolutely perfectly!!!!
By getting the right size point of light and moving it back and forwards so as not to overheat the surface, it warmed it up enough to flatten out the scratch marks!!
That's a brilliant idea!
So simple and perfectly effective.
Perhaps it could work also to weld steadily some separate parts directly on the figures without glue...
I prefer scalpels for flash removal and similar stuff, but hearing about pins on corks I suppose I found a better way...
When I work with pins or other similar stuff like nails or needles (especially if heated), I hold them with a "mine lapis pen" (don't know exactly how to translate it...) I mean those pencil pens with a metal chuck on top to hold the graphite sticks inside.
Actually is like working with a pen with a pin at the top, much easier and comfortable to hold than a cork.
Pushing the back button of the pen open the chuck to adjust the length, releasing the button the point get firmly grasped.
If the pins are too thin to get grasped tight I wrap some tape or paper with glue around the pin poles to thicken them.
