You will have noticed,that I`ve put a tick on one side,this is something I like to do so I can stick them all in the same way in this stage of construction.This is in case ,one edge is slightly different from the other, and it keeps things tidy!
Put plenty of PVA glue on the edges to be stuck ,each peice on at a time and just leave them to one side for a few minutes,then add more glue,and don`t skimp on this,and stick them and stick them to the side of each line so you can see what you are doing.
The extra glue slightly squeeze`s out and will form a nice bound of strengh around each section to be placed in this way when it dries. At the same time of fixing the first glue put on, bounds very quickly to the card,and you`ll save bags of time by not having to hold each section in place for to long. Don`t rush it and let the glue do the work for you.I must just add, I use waterproof PVA glue and it`s thicker and stronger then the cheap stuff!
With the cheap glue you are paying for about 40% of water, so I strongly advise you buy the best. Also don`t use contact glue it will make your model to bendy, and it`ll end up in the bin,and with all your work wasted.If you wish you can use PVA glue like contact glue simply by letting it dry off a little before fixing,But I like to use the glue as I`ve already described and in doing so get the very best of the two system`s.
