Removing Flash and mold lines
Posted by Chasseur on 01 Apr 2009, 03:11
For the most part I will use an exacto knife to carve off the mold lines on plastic figs. I saw an article where a fellow heats up a paper clip and melts them off. I tried that technique but is doesn't work very well. Does anyone in this forum have a better way that they could share?
Chasseur
Chasseur  Canada
27 Nov 2008, 03:47
Posted by Fenton on 01 Apr 2009, 06:26
I use a sharp knife, I also have used the heat method, but I use the flast of the X-acto blade instead of a pin.I only use this to get rif of any nasty bit of scraping marks that might occur
Fenton
29 Oct 2007, 05:53
Posted by Paul on 01 Apr 2009, 07:00
A razor blade, the old style double sided ones. They can be cut to a fine point
Posted by Michel on 01 Apr 2009, 07:01
I always use a sharp Knife like a Sorgeon use it!
...and change the Knifeblade often!
Michel  Germany
02 Apr 2008, 08:21
Posted by Benno on 01 Apr 2009, 07:25
A sharp razor blade. Martin here has some real good ones (got mine from him too).
Benno  Netherlands
Forum Admin Forum Admin
07 Oct 2007, 16:31
Posted by Maurice on 01 Apr 2009, 08:49
Big pieces with a scalpel, small lines with a piece of thin metal wire that's been kept in a flame for a couple of seconds.
Maurice
04 Jan 2009, 15:59
Posted by Chasseur on 02 Apr 2009, 04:03
Thank-you! all for the tips....Chass
Chasseur  Canada
27 Nov 2008, 03:47
Posted by T. Dürrschmidt on 02 Apr 2009, 08:01
It´s also a good idea to freeze the figures. So the flash is easier to remove.
Posted by Paul on 02 Apr 2009, 08:32
Freeze them? :? Would that work with all plastic types, and then with a scalpel or heated metal wire?
Posted by T. Dürrschmidt on 02 Apr 2009, 19:02
With scalpel. It helps to make the flash harder... Works quite good. I don´t know if all kinds of plastic work with this method....
Posted by dutchboyinohio on 02 Apr 2009, 19:15
Freezing the figures, what a good idea! I'm assuming then you'll also have a lot less fuzz left over once you're done cutting off the flash. That's always my biggest problem. :eh:
19 Feb 2008, 06:51
Posted by ModernKiwi on 02 Apr 2009, 20:02
Of course none of this helps when you are dealing with Redbox's figures... :-D For them I use a kitchen blowtorch to melt them down.
ModernKiwi  New Zealand
23 Jun 2008, 10:36
Posted by Peter on 02 Apr 2009, 20:54
Benno wrote:A sharp razor blade. Martin here has some real good ones (got mine from him too).
Me too (Martins razer blade ;-) )
Greetings Peter
Posted by Paul on 03 Apr 2009, 09:13
ModernKiwi wrote:Of course none of this helps when you are dealing with Redbox's figures... :-D For them I use a kitchen blowtorch to melt them down.
It worked with the smurfs (sorry Dacians) from Strelets :-D :-D :-D
