I had wanted to paint up a few Spanish light horse, and had some unused French Hussars from the Itlaleri French Command set. So a quick look at my Pinterest page for Spanish cavalry came up with these guys, technically horse grenadiers but hussars in everything but name.
Because the figures I wanted to use had pelisses rather than the short coat it placed them later than I really wanted, at 1812 when they received new uniforms from the British. But they were close enough to the older uniform that I thought it worth the trouble. To make them a little more generic, I sculpted campaign dress riding trousers for the bulk of them, leaving the officer and trumpeter in their post 1812 lemon yellow riding breeches.
I was pleased with a solution for the riding trousers' buttons, using the tip of a .5 drawing pencil (minus the lead) to imprint the sculpting compound. Other than that, alterations were few: I carved off the colpaks from all but the officer, swivelled a few heads as there were only two poses in the nine figures and switched one to a trumpeter with the use of an arm from some other set of cavalry.
I lacked horses from the command set, however, so I used instead horses from the Italeri Prussian Currasiers set (1806/7). The shabraque was all wrong, so I sculpted a more pointy configuration and, added a pack on the back of the horse. I did a bit more work on the officer's mount, giving it a sheepskin saddle with wolf teeth fringe, and a longer shabraque, using my reference as a guide.
I will post more pics of them when they are painted and mounted, but I was generally pleased with the results.
Trooper 1808
Officer 1812
The full nine figures
Trooper with campaign trousers and button maker
Trumpeter
Commander, with sheepskin saddle and longer shabraque
