Posted by Taipeh on 22 Oct 2015, 08:22
Hi ,
as my figure are allways ready for paint, you normally Need no reducing of sprue block or flesh.
As the rifle normally are casted extra in pewter you have to glue this the the figure. Super Glue is
the best result. I prefer "Loctite" from USA , only Little drop with a pick.
Than you have to prime the figure, but this should also be done with pewter figure, so it is the same. I use cheap primer from Automotive section.
After this you could paint with each colour you used normally. Acrylic or Emanel
Ciao and looking Forward for the result.
