Questions
Vallejo Plastic Putty
Posted by Peter on 29 Sep 2014, 21:54
Does anyone know this product? And what is the best way to use it?
Posted by Bramble15 on 30 Sep 2014, 01:56
Yes sir, I have it and have used it many times. I like it for filling small gaps either in figures or models. it is a smoother type putty that works well with a wet finger. It dries relatively fast if you don't slop it on. it is a good product with many uses however for models or heavier construction I like the green putty from squadron the best.
18 Aug 2010, 22:25
Posted by Bramble15 on 30 Sep 2014, 18:36
Sorry - last night I meant to complete my thought(s) but got sidetracked.
My comment related to models or heavier construction, was realy geared towards plastic models that may have larger type gaps when constructing. I cannot say that this product would not work for that application I can only say that I have not attempted to use it as such.
I have used it for 18mm figures/horses, 1/72 figures/horses, 1/72 tanks, 1/35 hard plastic figures, Hat 54mm medium plastic figures and have had no problems.
18 Aug 2010, 22:25
Posted by Arekmaximus on 30 Sep 2014, 19:34
I have it in use. Per dries quickly and is too dense. I do not recommend.
Arekmaximus  Poland
18 Sep 2014, 19:48
Posted by Peter on 01 Oct 2014, 11:32
Thank you for the input gentlemen! :thumbup:
I was planning to use it for those Art of Tactic figures from Zvezda. Sometimes the arms don't fit well. ;-)
Posted by Kekso on 01 Oct 2014, 12:24
Hi Peter... Will you let us know the result if you will try it? I have a lot of Zvezda figures (big sets) with separate arms.
Posted by Peter on 01 Oct 2014, 15:12
Kekso wrote:Hi Peter... Will you let us know the result if you will try it? I have a lot of Zvezda figures (big sets) with separate arms.
I have some of those to. I let you know what the result is! ;-)
Return to Questions
