Posted by Emperor on 25 Jan 2014, 01:07
You have Carlo Antonio's tutorial Russian and French infantry painting guide PRIVATE...
Anyway the tactic for me is next...The final product depend of how you use the paint...
As I noticed, if you use paint extra tinned, you can achieve the result of shading during putting base coat...Reason, simple, the pain and water mixed in proportion 50:50, will equal flat paint, with no difference, the extra tinned paint in proportion 80 water 20 paint will give result as wash gives, that means paint will be too liquid that in cracks will get more paint than on surface...
Now for painting, the white presents the greatest problem...White in spectrum of light by observer eye present all the colors in one color...That is why every mistake is visible...White color is better form Games workshop than from Vallejo...Vallejo must be tined, and applied in few layers...Before that you put a coat of grey color...
Now Napoleonic figures present more problem than other, because of extra details in form of tin belts...In my early stage of painting, I had this problem with using 4 brushes...During the work, I would ussally mix brushes, and after using one brush for thin parts and large surfaces, the brush will get fuzzy, unable to paint small details...The solution is human saliva...
As for method...Method is systematic...You paint many figures, first you paint the largest area on all figures that means uniforms pants...Only when you do largest area, you do the small details....Don't concern painting over small details with uniform colors...When its dry apply the layer of paint for details...I f you accidentally put different paint, just take a lot of thinner or distillate water, and apply so the paint can dissolve...Than pick that water with dry brush...
