Ben Bob wrote:Something I only recently learned is to NOT dip the brush too deep in the paint. Just some on the tip works. It is slower but I think that it helps preserve the brush longer.
That's a very useful and important tip!
But sometimes, for accident or due some particular uses, is impossible to avoid that the paint "climb up" from the bristles top to the join with the brush body...
I noticed that a good habit to keep brushes in good conditions and prevent wearing damages, is to rinse them often while using them.
I avoid to use a brush to paint the same color for a long time and wash it only when the job is finished,
for example, while painting several figures I rinse the brush often and several times meanwhile... once finished one or two figures, I quickly rinse the bristles gently before starting with further figures.
This prevent eventual paint to accumulate and dry on the bristles, and allow to clean it well when the job is finished.
It means a little waste of time, but this way is very unlikely that paint remains inside the bristles.
So there's no need of final "intensive and hard cleaning" or strong thinners to wash the brushes properly.
And the brushes then don't need to be restored at all, lasting much longer in good conditions.
